Thursday, April 19, 2018
The OPC Community Forum.
The I-7567 is a USB to HART Converter
Sending data from SCADA to LabView using HART protocol
hi,
i have project on Scada system for acquisition Data from 10 Transmitter and send it to PC (HMI application LabVIEW) with HART protocol. so when the solution i find The "I-7567 is a USB to HART converter." my question is how to access directly to LabVIEW?
Thank you
We suggest to use one of our Hart to Modbus Converters.
For Modbus RTU (serial), you can use HRT-710
http://www.icpdas-usa.com/hart_710.html
For Modbus TCP (Ethernet), you can use HRT-711
http://www.icpdas-usa.com/hrt_711.html
A Modbus Library can be found here:
http://ftp.ni.com/pub/devzone/epd/nimodbus121.zip
Use an OPC server for HART. I think LabView supports OPC. Please check.
Learn more about OPC from this book:
www.isa.org/autosoftware
Jonas
